starter problems help ASAP
89supramk3
arlington tx
:evil2: ok i have a 89supra n/a auto but i have a problem with my starter i did a jdm n/a swap recently and my starter dosen't even work i got to turn the ignition and all you here is the relay switch going on and off nuthin from the starter at all it like a clikcing noies coming from the passenger side but like i said you can here that relay switch cliking on and off. But heres the wierd thing i went to get the starter tested and it worked as if new and it has 124k on it. all the cabels are hooked up the groundes are were they should go just like on the other block but when i turn the key it won't start.but before i did the swap i was told to tap the starter to losen it off the flywheel because it can get stuck
8,894
The reason you "tap" a starter is the contacts are wore down. You are just vibrating it closer.
That kind of sounds like a discharged battery to me. You need much more amperage to turn over the engine that just engage relays, radios, and lights.
mkiiSupraMan18
Needs a new username...
United States
Is your neutral safety switch hooked up (or jumped?) ? That little button thing on the clutch pedal hooked up? Also try rocking the key back and forth from off to start fairly quickly, I had to do this w/ my mkIII after it had set awhile (when I got it). Thats really all I can think of. HTH.
Dirgle
Conjurer of Boost
Pauma Valley, CA
Stock alarm may have been tripped. Close your doors and lock then unlock them with the key. That should disable the starter kill.
Also just for the hell of it double check to make sure you battery connectors are tight and not corroded.
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
I had this problem 2 times now. I'm on my third starter. I just had to hit it a few times with something. Its easier if you have 2 people. One in the car to hold the key to the start position and u to tap the starter. This method works really well. But this may not be the problem but it was for me twice. Good luck.
89supramk3
arlington tx
:evil2: ok i tride the nutral safety switch that didn't do anything and i tride with someone with the key in the start postion and i taped on the starter but theres a red battery light on in the car also what about just getting new starter terminals
89supramk3
arlington tx
ok ok this battery on my car now show 12volts. when i go to start the car no voltage drops or anything but that red battery light is on now and this battery is new.......... Oh and for the alarm it won't turn on i don;t have the factory alarm remote but for some reason with this battery it won;t turn on but with the other battery before this one. It worked just fine but im just gonna buy a new starter and a new battery so this can all workout the right way:evil2:
I6BajaPickup
Phoenix, AZ
Damn I have the same thing going on with mine right now... I took the starter out and it tested fine. Put it back in and fixed some wires and it still just goes 'click!':icon_conf
89supramk3
arlington tx
hey man just get a new one its probly your starter silinoid conections... meaning there just wornout or that u just have a high mileage car iv'e cheacked everything even the key ignioneverything on my car was fine and untouched it only has 124k on the car when i bought it but with new jdm engin its 40k so if you have a high milage car u will soon fall to starter problems
