Starter for 1JZ
rtboy02
62
highland, utah
Well the 7MGTE starter doesn't work (much too big and its not a direct drive starter).
I've been to all the auto parts stores in town and looked through their starters. No luck.
Anyone know where to find a new starter for the 1JZ R154?
BigTSetter
Denver
the 7M DOES! work. I've got that on mine RIGHT now, and it works great. Several other guys on SF also have the 7M starter on their 1JZ MA70 Supra
supramanmk3
Supra : PRICELESS
Jun 12, 2005
22
New Jersey
For what I've heard at Supraforums, 89+ 7M starter should fit. Others have suggested 2JZGTE, 2JZGE, Lexus GS and SC (not sure about the yrs) HTH.
rtboy02
62
highland, utah
Sorry, but the thing doesn't fit. Its about 2 inches longer than the 1JZ one.
I need a direct stock replacement 1JZ R154 starter. Anyone??
BigTSetter
Denver
the starter that i'm running on my MKIII Supra 1JZ is a 7M starter!
Yes, it IS longer, but it still fits with no problems
rtboy02
62
highland, utah
I fabricated my own engine mount adapters to fit my 86.5 subframe. Mine are quite beefy and the extra length of the 7M starter does not fit. I tried for half an hour from various angles until my arm was too tired to hold the damn thing any longer :icon_conf
rtboy02
62
highland, utah
zoonwen said:
whats wrong with your starter ?? dose it click alot before it kicks in ??
Yeah I usually have to turn the key 20-30 times to get the thing to start. Finally, on Saturday I tried for 5 minutes with no luck at all. It does click every time and its getting plenty of juice (tested with a multimeter).
Either the contacts are dead or there is some internal wiring that is failing.
rtboy02
62
highland, utah
Nevermind, I found a source for a JDM 1JZ starter.
$208 from Champion/Jay Marks Toyota. $30 core refund brings it to $178. Kinda expensive, but I really have no choice. At least its brand-new OEM and not a crappy reman :icon_bigg
BigTSetter
Denver
Ah! okay, now that makes sense. I'm sorry that i was stubbern in pushing that the 7M starter will fit. I have that on my car with Orin's engine mounts with a 89+ crossmember. I've know several other guys with this setup as well.
You have a different situation, therefore, your clearence issues are not the same as what others have.
Thanks for sharing that info with us. :D
Hope you get 'er running.
Bryan
rtboy02
62
highland, utah
Thanks Bryan. You weren't being overly pushy or anything. I should have specified why it didn't fit in the first place. The holes for the bolts and the teeth on the gear are the same and it looks like it should work, but try as I might I can't get the thing lined up due to interference.
The 7m starter is about 2 inches longer and much heavier than the 1JZ starter. I suppose I could have taken off the engine mount on the driver's side, but who wants to do that to install a starter?? :)
BigTSetter
Denver
NOT ME! It's not fun replacing our starters in the first place! Let alone i can't imagine actually having to jack the engine up.
Good luck,
Bryan
