I bought a turbo mk3 a few weeks ago that had a BHG, i did the head gasket, new belts, new seals and also blocked off the EGR. I also made some intercooler hardpipes, put a greddy typr RS BOV, 62-1 CT26, and an HKS PFC F-CON. Now, I went to go and start it and it runs for less than a minute with idle from 400-700 RPM. I removed the F-CON system and had just the stock ECU and still nothing better. Its flashing codes 51 and 14. I checked the resistance in the TPS and its within spec, i have spark. I have Bosch Platinum 2's in it now, Ive heard bad reviews about those, are those my problem? When the car starts up and you try to give even just a little bit of gas, it dies. Could it be a harness issue? The timing belt is set to 0 deg. at the crank pulley. I just put fresh gas in it I am really frustrated right now and cant think straight:3d_frown: , any help would be appreciated.:icon_bigg
