Start for new rebuild
7Matt-GE
407
Becker, Minnesota
CP pistons are some of the most expensive but some of the best. they hold well above 500 horse and a good combination with eagle rods. that is if you can afford them :)
also, im a sort of an NPR engine bearing fan. check them out.
one of the few bearings that can hold 1000+ horse in a 7m
fyi. ken blocks old subie rally car had CP internals in then
suprarich
Guest
Nov 9, 2005
2,187
ohio
Who's motor is running 1000+ HP with NPR bearings?
suprarich
Guest
Nov 9, 2005
2,187
ohio
ahh, typo, gets you every time.
To the OP - With CP pistons, eagle rods, and good bearings installed, any failure would not be the fault of those three items for 500 hp.
JStoked
646
Edmond, Oklahoma, United States
carmsbody;1656056 said:
which engine... the stock 2j bottom end can handle that power fairly reliably
No man a 7m.
---------- Post added at 06:49 PM ---------- Previous post was at 06:44 PM ----------
Ok cool was going to go with federalmongahal I think that's how you spell it I can get them fairly easy. Are the ok?
---------- Post added at 06:50 PM ---------- Previous post was at 06:49 PM ----------
laotionracer101
389
Arkansas
JStoked;1656687 said:
No man a 7m.
Federal=shit :icon_evil .. Try 6 times spun, in a 2j... 9 rebuild coming soon.. :3d_frown:
laotionracer101
389
Arkansas
JStoked;1656753 said:
O crap ok I'll shy away from them. How about king rod bearings?
acl, king, are rated better, I will be using either or for the 7m and 2j rebuild coming up, it might be a good idea to get both to test.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Federals are a good bearing, kings are not and have been proven not to be in a 7m. Federals are sometimes used by Clevite for very odd sizes, as NDC is used by clevite for nearly all STD and many -.25mm now. Just stick to OEM bearings or Clevite/NDC, there is no reason to use anything else.
1300 for a set of what?
Blackdawg
Taco Soup..my rides
Oct 12, 2010
247
Wyoming
just got done using ACL bearings..checked out great...idk how they will hold up when it runs..but hey its a start?
JStoked
646
For a set of cp pistons and eagle rods.
