Hi,
Need a good advice
So the problem
7mgte, had few problems with spacer between valves an cams
desided to fix the gaps
found that all ex. spacer are about 3.05mm and the gap is .35-.45mm
and one ex. cam holder (ex4) was faced wrong side
after making all gaps .35mm and placing the holder right direction I discovered strange noise, knock, thought that the rod bearing came to an end.
So after engine removal (bearings were fine) changed bearing to new ones (same STD size) put all together and the knock still in place.
tried everything but the knock still can be heard, it is like the rod knock but comes from ex. cam, or somewhere there.
allso one bolt on the cam holder was broken, nothig can be don there (ex6)
What can be the problem ???
Need a good advice
So the problem
