Standard vs Inverted Shock Design. Advantages/Disadvantages?
Ma70.Ent
1,871
NJ
As the topic says, what are the advantages of each, or is one completely better in every way except cost? I've heard that Inverted > Standard, but I'd like to know why (a true explanation). I know people have said that inverted is less weight, more durability, etc. but no explanation why.
Thanks!
supraguru05
Dec 16, 2005
737
louisville ky
IJ.;1255948 said:
Inverted is usually done to reduce unsprung weight.
DING DING DING Winnar
however you cant invert hydraulic shocks only gas shocks
at least i think i have that the right way
Wiisass
Yeah, less unsprung weight/inertia. Although it's really not that much of a difference if you're using a good shock. Also usually sucks for packaging on a street car.
And you can only do it with pressurized shocks. The cheaper twin tube shocks that aren't pressurized will not work. But any good monotube and really good twin tubes and you're good.
