If I accellerate to 3000Rpm+ the car simply dies. This is only under load, I can however rev it ro redline at a standstill. Timing is dead on, my brother thinks it could be the distributor. Any ideas? The exhaust definitely is not clogged as I have pulled it. I dont see how clogged injectors would cause this and run fine at lower rpm's Anything else ignition related I should check? Could bit be the TPS?
