ST Anti-Sway Bar Kit
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Does anyone have a pair of these on their supra?
Is there really a noticable difference on the street thru turns or is it mainly used for the track?
Cheapest I've seen are at $222 which aint too bad.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I'm not sure what Noah89T's set up is, but it is amazing. We went through interstate exit loops at 20 lbs of boost, without a bit of body roll or wheel slide on the way to CHI2K7. It scared the shit out of me the first time we did it, but became something to look forward to before we got home.
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
I have them on my car.....yeah I would say there is a noticebale difference! I can easily take a 35 mph exit ramp at damn near 60...you will have some body roll but its not bad. I think Wiisaas was supposed to be testing all the different sway bars to see what kind of a difference (if any) there is between the aftermarket ones and stock. I picked mine up for $120 (used)
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Yea I remember seeing that thread a while back....Did he get any results?
twinturbozs
131
san francisco
IMHO, the whiteline bar is much stiffer than the ST bar. The difference in feeling going from stock to ST is about the same going an ST to a Whiteline bar. I would spend the extra $$ and go stiffer, youll appreciate it in the end.
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
I use the ST bars, they're a great improvement over stock. I've heard that the Whitelines are better but for a street application the ST's are more than sufficient.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
I don't see why the ST's would be better for street than the Whiteline's since anti-sway bars shouldn't affect your ride too much, just the amount of body roll. Seems to me it would be more of a preference/driving style thing.
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
I have the ST bars. I would say yes massive difference over stock. When you remove the stock bars you will know why. I can take turns at a much higher rate of speed and not loose tire contact. The rear bar is a PITA to install though.
