Sputter at high RPM
againstdawall06
298
mo
ok basically in first at high rpms my 87 turbo supra sputters.its not like a vilent one, it just makes a sputter sound and loses power. i have exhaust and a filter. im boosting about 9-10 pounds. it only does it in 1st and 5th sometimes. no boost leaks. when i up the boost to about 12-13 it does it really bad in all gears. im affriad it could be leaning out. would that cause something like that? could it be the stock plugs-wires? any help or info would be nice.. and i searched, but i couldnt find anything. atleast links to threads that i missed during my search would be nice.
thanks for any help
andrew
againstdawall06
298
mo
jkbmkiii said:
thats what Iam saying, PLUG GAP!
no idea. i havent changed the plugs since iv owned it. i have NGK plugs sitting on my dresser though. im waiting for my next paycheck so i can get NGK wires. would that prolly be it? what is the gap i should run? just spec gap or something different?
jdub
Feb 10, 2006
10,730
Valley of the Sun
The stock plug gap spec is .031 for a turbo motor and should be fine if you are running stock boost. If you run boost above stock, gapping the plugs down a bit like IJ suggested will usually stop the studder. New plug wires like you're planning to do is a good idea, especially if your stockers are old ;)
djordan97
199
Kennewick WA
there is always the possibility that you are hitting boost cut. that starts at like 11.5 psi but can be adjusted up to I think it's 13.5 psi by turning the screw in the afm.
againstdawall06
298
mo
no its not fuel cut. iv hit that before. totaly different. its not like a rough cut out of the engine, it just makes a sputery sound and get real weak. my timing is also at 12-13 degrees. if it just the ignition it not a big deal but i im just really hoping im not leaning out already. i would buy a wide band but thats WAY out of my price range.
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
hey guys, my car is doing the same kind of thing, it pulls real good up to about 5k-5.5k and then slightly sputters and stumbles. when i have a passenger they can't hardly feel it, but i can. i know i have a slightly bhg. i ordered my mhg and arp head studs last tuesday, so im acctually taking my car apart tomorrow. im pretty sure that the very small amount of liquid that is getting in the combustion chamber is what is causeing the stumble. anything that throws off the air-fuel mixture will mess with your car and it won't run right. as for stumbleing cause of a lean mixture, it can't be that. your car will pull real hard if it is lean, but it will eventually explode. it is more likely to fall on its face when its rich, which is what 7m's are known for. when i get my car back together ill let you all know if the new hg fixed the problem
againstdawall06
298
mo
it shouldnt be a BHG since my hole motor only has about 6k since its last rebuild. and its not showing any signs of it. i hope its just the plugs/wires.
There is a point in the power curve at maximum cylinder pressure that spark blowout can be an issue.
At 30 psi for me with a .025" plug gap it happens around the 5300 point (max Tq) I've bumped the timing up a touch at this point to tune around this but normally you'd either raise the spark energy (new ignition parts) or back the plug gap down more.
Against: Just try knocking the gaps down before you start suspecting BHG's or anything mechanical, diagnose it one step at a time.
againstdawall06
298
mo
o ya i know its not that. it prolly will be a week or so till i get a chance to change the plugs and wires out . is it bad for the motor at all? even at about 6lb it does it at the top of first.
