so ya my speedometer doesnt work and what can be the problem, i know the speed sensors but what else
Dan_Gyoba said:The two basic possibilities are the gauge itself and the cable. Usually the cable makes noise.
Does the odometer still turn over? The odometer is directly mechanically driven by the cable, the gauge itself has a clutch which works against a spring. If the clutch lets go, then the gauge just reads zero all the time. It's also possible that the needle is just stuck at the gauge face.
If the odometer turns over, then the problem is the gauge itself. If the odometer does not turn over, then the problem is with the cable.
kabanimk3supra said:sorry to hijack the thread.
my speedo cable is missing and i have an na parts car.
does anyone know for a fact if the cables are interchangeable?
starscream5000 said:Yes they are interchangeble.
To all of those having erratic, bouncing speedos, they are most likely getting ready to take a dump on you. Lube them up now to forstall this.
That's the main killer of the speedo cable. They need to be re-lubed after 15 years of so of neglect. :3d_frown:
