hey my speedometer doestn work for some reason. i checked all the fuses and every other gauge works. could you tell me what is a possible problem and how i can fix it? thanks
johnathan1 said:What isn't working? The Actual operation of the guage or is it not lighting up?
Nick M said:The speedo is driven by a two piece cable. That cable is driven by the output shaft of the trans. The most likely reason is a problem with the cable. It might be broke at some point inside its cover.
89Turbo said:same thing happened to me, i melted it, more than likely your the lower part of the 2 piece cable....
supra90turbo said:it is a two piece cable on 5spd's.
we're not all autos...
