Speedometer/Gearing Question
a_sesshoumaru
Suprita
Jan 7, 2007
455
El Salvador
my speedo cable isn´t working since i bougth this car, i want to know how fast the car goes when you end 1st, 2nd, 3rd and 4th, with r154 stock transmission. Thanks
Sawbladz
1,727
Oshawa, ON, CA
The main culprit for a non functioning speedometer is the shorter cable that attaches directly to the transmission. This was the case when my speedo was broken. If you search, there are posts that explain how to go about trouble shooting your speedo.
If you fix your speedo...you can find out how fast you are going at the end of any gear you want;).
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
Do it Pimp My Ride style and drive next to someone and until you're tapping the rev limiter:evil2: , ask them how fast they're going next to you, write it on a sticky note and cover your dash. But really, dont do that, just fix the shorter cable like explained above. Or shift at 2500-3000rpm if your tach works.
-Chris
