Speedo Question
Boostin88T
Mk4 Slayer
Feb 23, 2006
29
Long Island, NY
Anyone know what speed I would be going if the needle pointed to the P in the middle of the MPH at the bottom past 150 speedo cutoff?
Or at least know the calculation to find out the speed.
I know it's past 160mph but made me interested.
Supracentral
12
Factory speedometers are notoriously inaccurate as you get to higher and higher speeds. When you are operating outside the marked range it would be hard to say with any degree of accuracy. Really freakin' fast would probably a good statement. :)
Boostin88T
Mk4 Slayer
Feb 23, 2006
29
Long Island, NY
xarewhyayen said:
r154? what rpm were you @? Whats the gearing of your diff?
Yeah, R154 at around 6300rpm ish. Don't remember the gearing in my car but it's an 1988 Turbo 5spd. I have a 4.10 gearset sitting next to me that I haven't put in yet.
Boostin88T
Mk4 Slayer
Feb 23, 2006
29
Long Island, NY
Speed Range according to the calculator that I just found was 171mph to 178mph. My friend in his 540 6-spd was suprised because he was crusing at 160mph and I blew right past him.
N
NDBoost
Guest
with a stock differential and trans setup and stock factory tires Top speed is approx 171mph.
Tirewidth: 225
Aspect Ratio: 50
Wheel Diameter: 16
Rev Limit: 6500
Overdrive Gear: 0.753
(89+ Turbo Differential) Final Drive Gear: 3.73
http://www.mysportscar.com/tools/topspeed.htm
antman
632
TN
iam sure glad i don't live near you. iresponsable driving like that gets people killed.
N
NDBoost
Guest
oh get off your soap box hippie:naughty:
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
With stock tires and the stock rear end. 6300rpm is 158.28MPH. If you blew past someone doing "160MPH" at 6300rpm in 5th, chances are his speedometer is off too, lol.
Even if you had the 89+ gearing, you'd still only be doing 166MPH.
(Unless you have an unholy tire size... what tires are you running?)
Boostin88T
Mk4 Slayer
Feb 23, 2006
29
Long Island, NY
275/45/17 Tires and 3.91 rear w/R154.
Oh, my speedo is probably waaaay off...I was laughing when it pointed to the MPH at the bottom.
Btw this was done on a closed off highway with no one there.
