SPEEDO FAILURE
IETV8S
1.5JZ WOOT WOOT!
Mar 24, 2007
60
calgary
so i turned my car on and went to the store, my speedo worked fine, when i letf the store, it stopped working, i checked the speedo cable and it was still hooked up any suggestions?......also the tensioner pully i believe finally wore out and broke, what is the part number for that?:aigo: :3d_frown: oh and this is on a 1jz
supradaddy0803
1JZ Beater
Jul 25, 2007
46
Athens,TX
There is a little pigtail next to your tranny for the speedo cable that always breaks I have replaced them many times takes like five minutes. It costs like 11 dollars and you have to get it from toyota. Just look under the car from the tranny back and you will see a foot long section that has a screw off disconnect and I guarentee it is broke right next to the tranny cause the key peice will fall out.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
do you have the 2 piece cable or the 1 piece? i have both and im waiting to see which to use for when i get my car running :)
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
if its the 2 peice cables, you can pull them off 1 by 1 and spin them manually to see which one needs to be replaced. It will save you alot of time if the first cable off the tranny needs to be replaced
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
i had the piece that goes into the tranny go bad :( same thing i was driving and then one second later no more speedo
IETV8S
1.5JZ WOOT WOOT!
Mar 24, 2007
60
calgary
i have the 2 piece one, i'll put it on the hoist and see, where can i get the T-belt tensioner from?...can i get it from a 7m?
Ronald
66
Cleveland OH
not to hijack, but I have same problem (well, my speedo never work since got the car),
MKIII with Aristo 2JZ, do I need the same cable/pigtail thingy? Are the parts compatible. This car has R154 Tranny...
Or should I be sourcing from a MKIV Supra or Aristo manual tranny?
IETV8S
1.5JZ WOOT WOOT!
Mar 24, 2007
60
calgary
that sucks, i dont have any access to thoese parts well the pully anyways, can i get it from toyota?
tlo86
Jul 24, 2005
3,914
Colorado
what transmission is in your car? you can see the cable coming out of where the gauge cluster is in the firewall and it goes down to the transmission
if you have an r154 you use the same cable
