Speedhut Gauges fookered my Needles
N
NDBoost
Guest
Well its all my fault, cant blame speedhut (the gauges look bitchin). I rushed things and got frustrated, so now my water temp gauge reads 3/4 hot instead of 1/2 or 1/4 hot. Is there a specific way to set these gauges so they are acurate?
my oil pressure is reading low as well and it wasnt before i ripped the needles off. Any advice/info would be great :)
N
NDBoost
Guest
well i know that but obviously when i put the needles on they werent put in the right position.
whats the right position..
do i have to turn all the needles to face down and then take em off and re align them or... gah
Suprastic
727
Manitoba
Why does everyone take of the needles to install these gauges. If the new gauges aren't stiff, you can bend them slightly and slide them over the needle. This way you are sure not to break a needle and you gauge accuracy will be the same.
N
NDBoost
Guest
well on the tach and speedo you HAVE to take them off, because the needles base is wider then the hole on the faces.
But i just overall fucked up the cluster, time to get a new one i think :(
