speed + gear = what RPM?
s383mmber1
3,614
Somers New York
Is there a chart that tells me for my car what RPM ill be at in each gear at a certain speed? I searched and couldnt find anything...
W58, 4.3 LSD with 17's
I dont think my tachometer is correct....
In second gear, at 20 MPH im at 1500 RPMS...
s383mmber1
3,614
Somers New York
245/45/17's
Im just trying to get an estimate, because im running open downpipe, and it seems like the engines working real hard at 2500 RPMs...
1 2 3 4 5
0 0.0 0.0 0.0 0.0 0.0
200 1.1 1.9 2.8 3.6 4.6
400 2.2 3.8 5.6 7.2 9.2
600 3.3 5.7 8.4 10.8 13.8
800 4.4 7.6 11.2 14.4 18.4
1000 5.5 9.5 14.0 17.9 23.0
1200 6.5 11.4 16.8 21.5 27.6
1400 7.6 13.3 19.6 25.1 32.2
1600 8.7 15.2 22.4 28.7 36.8
1800 9.8 17.1 25.2 32.3 41.4
2000 10.9 19.0 28.0 35.9 46.0
2200 12.0 20.9 30.8 39.5 50.6
2400 13.1 22.8 33.6 43.1 55.2
2600 14.2 24.7 36.4 46.6 59.8
2800 15.3 26.6 39.2 50.2 64.4
3000 16.4 28.5 42.0 53.8 69.0
3200 17.4 30.4 44.8 57.4 73.6
3400 18.5 32.3 47.6 61.0 78.2
3600 19.6 34.2 50.5 64.6 82.8
3800 20.7 36.1 53.3 68.2 87.4
4000 21.8 38.0 56.1 71.8 92.0
4200 22.9 39.9 58.9 75.3 96.6
4400 24.0 41.8 61.7 78.9 101.2
4600 25.1 43.7 64.5 82.5 105.8
4800 26.2 45.6 67.3 86.1 110.4
5000 27.3 47.5 70.1 89.7 115.0
5200 28.4 49.4 72.9 93.3 119.6
5400 29.4 51.3 75.7 96.9 124.2
5600 30.5 53.2 78.5 100.5 128.8
5800 31.6 55.0 81.3 104.0 133.4
6000 32.7 56.9 84.1 107.6 138.0
6200 33.8 58.8 86.9 111.2 142.6
6400 34.9 60.7 89.7 114.8 147.2
6600 36.0 62.6 92.5 118.4 151.8
6800 37.1 64.5 95.3 122.0 156.4
7000 38.2 66.4 98.1 125.6 161.0
Blackfin
Beach Bum
Jun 16, 2005
205
John's Pass, Florida
IJ. said:
Jon: I'll need a tire size :)
3.0:1 will do it on 285/35/18s
IJ:
You may want to check calc but I can't match that number unless I squish the tire diameter 2.5 inches or use a 3.32 rear. Either that or I have had one too many.
RPM = 6500
5th gear ratio = 0.753 (r154)
Tire diameter = 25.85 (285/35/18) (unloaded)
Rear end = 3.0
Speed = 222
Blackfin
Beach Bum
Jun 16, 2005
205
Poodles said:
not to mention you're supposed to run higher tire pressure for high speed...
I thought I would start out at like 10 or 15 psi and let the pressure build:).
IJ said:
BF: There will be considerabe centrifugal growth at 200 mph so it's all academic
Hmmm. That is something I never considered before.
jonny87turbo
203
ohio
i checked my car in second gear, is 20 mph at 2000 rpm. 7mge, 4.30, 17in rims
