Speed Density help?
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Getting to a time crunch here. I have searched here, full throttle and MKIIItech. I have found some good info but here is my question.
My car is running with MAFT Pro:icon_bigg However it is idling a little rich (afr 12), the rpm's are around 600-650 but there is a little pop happening everyfew seconds. Timing is @10 deg. I have new plugs gapped @ 28 because I want to boost about 14lbs on stock CT.
Upgrades: Walbro, RC 55O's, FPR (Aeromotive).
I have set the Maft Pro (speed Density) at the quick setup that is in the MP documentation. This is for stock 440's though.
I can't find any adjustments for using the IAT though.. When I start to rev up it gets even more rich and stumbles a bit when pumping the throttle.
I was wondering if someone has any config and system settings they could post. I need to get my car on the road...
Thanks,
