Spark Plug Question
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
Hey guys I was wondering if it was safe to use NGK6E's in my 1JZ or should I stick with NGK7E's? Reason I am asking this is that I have fouled 2 sets of NGK7E's so far.
For instance, I put in a brand new set of NGK7E's last night and put about 60km's on the car. My AFR's were not too bad cruising around mid 14's and a little rich under light boost mid to high 11's. My idle was around mid 12's which was a little rich so I leaned it out a bit.
I go to start the car this morning and it doesn't start.I figure the spark plugs fouled on me because it has happened before.
XMasta19
12
Orlando, FL
plugs don't just foul that fast cuz you're using the wrong ones...the 6097's are awesome, you sure everything else is right with the stinger and what not?
