Spark Plug grease / lube on threads?
Who
I bought some plugs at my local Napa and the parts guy told my to make sure and lube the spark plug threads and spark plug boot with dielectric grease. Now I have heard of putting a small amount of dielectric on the spark plug ceramic to ease the removal of the boot from the spark plug. Should I put any lube or any anti seize on the spark plug threads that mate to the head?
Seems to me that dielectric on the threads would insulate or prevent the spark plug from grounding itself to the head.
Thanks!
jdub
Feb 10, 2006
10,730
Valley of the Sun
Nickle (1600 deg F) anti-seize on the threads....don't go nuts with it. Dielectric grease on the ceramic/tips is fine.
jdub
Feb 10, 2006
10,730
Valley of the Sun
IJ.;1185895 said:
Antiseize on the threads here after unscrewing a plug thread on an aluminium head many years ago :(
Ditto!
Steel threads doesn't play well mating with aluminum ;)
Supracentral
10
I guess it depends on what you're running.
If you are running close to stock on platinum's, they might be in there long enough to cause a problem and anti-seize is a good idea.
If you're running 28 psi, race gas and copper plugs, the damned things don't stay in long enough to seize, trust me... ;)
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
That must be why I never had problems... hehe.
fool'ssupra
Building It
Sep 14, 2008
75
Maryland
My car's just stock, but I always use nickel-based antiseize when I'm working with aluminum threads or high-temp threaded parts.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
What SC said makes sense, I would judge based on that for your application.
If you do put though, the torque spec becomes less acurate and you need to increase it a bit.
