sounds in the motor?
boltpride05
Lets Wrastle!
Apr 17, 2006
SAN DIEGO
Well i have a 87 N/A and just recently it started to make a wierd noise. It sounds like a bunch of rattling and you can hear it more when your in gear. It sounds like something is loose but i dont know. Maybe some of you people have had this problem before. I hope someone can help me. Thanks
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Known rattles include some of the following:
Loose exhaust clamps and hangers
Loose manifold heat shields(not sure on N/A's)
Loose crank bolt/pulley
Broken lower timing gear flanges
But it is really hard to help with such a poor description. See if you can pin point the area of the noise better. Take a video for us with sound and we may be able to help more.
boltpride05
Lets Wrastle!
Apr 17, 2006
SAN DIEGO
its commin from the engine. When i put it in gear its starts to make the sound then it gets louder as the rpm are higher. it only makes the sound when im in gear and moving.
1TuffSupra
Sho' Nuff
Jul 11, 2005
500
Raleigh, North Carolina, United States
yeah rod knock is when the bearings on the rods start wearing down due to either a lack of oil or a lack of changing the oil. Basically the bearings end up knocking against the crank and cause that rattling sound your hearing. What you can do to test it and verify that it is in fact rod knock is start unplugging the plug wires a cylinder at a time and revving the motor up. If the sound stops once you remove the wire thats the cylinder with the knock. Hopefully that isnt what it is though. If the knock is mild you may get away with just replacing the bearings and be ok, but once it gets bad you will either have to rebuild the motor or replace it with a jdm motor or something equivalent.
Mine started out very quiet, lasted about 1000 miles before it got really bad and I didnt feel comfortable driving it. It probably would have lasted longer but I was pushing the car on the hwy (for probably about .5mile, my house is only 3 exits down from where i work) and by the time I got off the highway and stopped at the light the car cut off. I cranked it back up, but it was knocking like a bitch. I ended up getting the car towed to my house and havent driven it since. Long story short, just make sure you are VERY gentle with the car until you discover the cause of the noise.
