Sound of TiAL BOV
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
from what i heard its pretty silent
I went with one like the tial but its a forge bov clone it haves a deep tone to it instead of a hi pitch whistle. the tial is more silent and keeps cops off your back but wont scare any vipers off.
drjonez
the motor city
www.4cefed.com
dcrusupra said:
What does the TiAL BOV sound like on 8-12psi?
when properly used, the tial is nothing more than a PSSSSSSSSSHHHHHHHH. the problem being that it's a HUGE valve and needs a fairly stiff spring to keep it from being open @ vac. that leads to surge @ such low boost levels.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
As DrJ said, hearing it in person, they simply have a heavy "WHH-PSHHH" sound...
But for some ***strange*** reason, when you listen back over it in a video, it has a weird and very VERY unique..."DOOF" before the whiplash sound.
I love mine. Best BOV I've ever ran. I've got an 11psi spring, will half-ass flutter at 1-2psi, anything after that is very clear. Super responsive, does its job, looks great & has a very intimidating sound. ;)
-Jeff
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
If you're putting a Tial in the supra you must use the stiffest spring they offer (11lb spring) anything less will leak air out of it when not boosting. A healthy supra pulls in 20-25 in/hg at idle and the 11lb. spring is for cars running like +20 in/hg IIRC. ;)
Boost Lee
2,750
Indianapolis, IN
forcefedsupra said:
To me it sounds a little like eighteen-wheeler bov's, sharp like a whip crack.
Yeah...
No.
No throttle [body], power is controlled by the amount of fuel which is injected...
Which means no Blow-off Valve.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
I don't know EXACTLY what spring I have in my tial, but I make an ass out of you and me to say it's the softest TiAL offers... and I have NO issues at all with it.
No leaking boost, no sucking in vacuum.
Justin
Speakers?
Spokane, Wa
I got the 9 PSI spring at the recommendation of HPF. Don't have any results yet as my ic setup is still being built.
Warning: Shameless plug..............:biglaugh:
You can barely hear mine when I do some wimpy burnouts but it's a Tial. I'll check my dyno videos and see if you can hear it there as well.
http://s121.photobucket.com/albums/o233/da89soup/?action=view&current=MOV01251.flv
It sounds soo much better when you're coming off of a good pull. It isn't loud when you're barely getting on it, but it sounds pretty sweet after you've spooled a good bit. Here is one of my dyno videos. You can hear it pretty good in this one. I happen to love the Tial BOV.
http://s121.photobucket.com/albums/o233/da89soup/?action=view&current=MOV01215.flv
