Someone Please help me find these gaskets(pics inside)
C
cnewingham
Guest
I have the HKS long runner manifold (7m) and need the gasket between the wg tube at the bottom of the manifold. And also the 50mm gasket on the wg itself. Does anyone know to get these?
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
rakkasan said:
can't you make it yourself? Does your local auto parts store have bulk gasket material? If so, buy some & cut it out.
I think the ones you can make urself won't last in those exhaust areas...most of them are cork or cardboard material.
IF you go to a mufflershop that does like larger trucks and vehicles, they can hook you up.
Also look up ATP, they maybe able to supply u with them.
C
cnewingham
Guest
I have the sheet of exhaust material and it will NOT hold up in that area. It is a huge pita to remove that also while it is in my car so I dont want a chance of an exhaust leak. I will check ATP.
Dziuggy
eurotrash
san francisco, ca
dziuggy.com
btw i have checked for these and manifold to adapter is 2" ID standart 3 bolt gasket. there is place on ebay that sell that size flanges so they should have gasket as well. also check summit
staticpat
Supra Chair!
Birmingham, AL
I was searching for a whole day for a similar gasket (mine was 3" ID). If its the standard flange size then you should have no problem finding one at a muffler shop. I had to go to a local industrial rubber and gasket company. A guy there gave me a sheet of some multilayer metal that I could cut to size.
