Hey guys. I've done a lot of searching, and I can't find much info on either of the following questions.
(Regarding Comp Cams Part# 975) So, from what I've read, these don't fit perfectly. I saw that there was some speculation over whether or not the Comp springs would wear the sides of the bore. Has anyone broken down a head that ran these springs for a while and inspected it? When I told my machinist that they wouldn't fit just like stock, he warned me that a lack of clearance around the spring might create metal shavings. :nono: In your experience, will the Comp springs cause the head to wear out faster?
(Brian Crower Springs) Do the BC springs fit more like stock than the Comp ones? I've noticed that these springs are most commonly sold in a kit with retainers. Is it possible to run these springs with the stock retainers? Safe? I know what happens if a retainer breaks. :cry:
Thanks in advance!
Thanks in advance!
