I'm running 7lbs of boost, fuel pressure base at 32lbs with vac. Afr's are good (btw 11 and 12) up until WOT above 3000rpms, then it just goes flat 10. Before i switched to the Lex afm, i was having a problem with the wastegate door sticking shut, and i was hitting fuel cut. I've since fixed that and now want to increase the boost. I'm running a super conservative tune for now, should I incrimentally increase the boost till the mix starts to lean? or should i make the tune leaner (afr btw 11 and 11.5) then increase boost a bit and retune? the car as it sits today: worked 7mgte, 680cc injectors, lex afm, stock turbo, super AFR, profec b.
