some pictures pease!
jsnowman76
In need of another supra
Oct 17, 2006
289
Elk grove, CA
could someone please post up some pictures of the engine bay in a pre 89 turbo. The previous owner has some modifications and or re-routings that really don't look right. could I get some help please.
catback
bitterville
not sure how much this will help...:biglaugh:
but i just spent 3 hours polishing, and wanted to show it off:icon_bigg
jsnowman76
Oct 17, 2006
289
Elk grove, CA
thanks man I'm diggin the clean bay. did you fabricate the hardpipe for the radiator yourself? can I get a couple of closeups around the engine bay especially the upper radiator where it connects to the block side. also what happened to the cruise control? how did you reroute the vacuum lines?
catback
bitterville
thanks
polishd stuff is so hard to maintain:cry:
as for the upper pipe.....
nothing a trip home depot cant take care of;)
i havent seen anybody route the ISC vac hose how i have it either.. cost $0.00 :)
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Is that just a hole in your cam cover? Or did you get a cover for it?
Also, What type of cables did you use for the coilpack relocation?
catback
bitterville
yeah i just cut out the cam cover.
the wires are custom length MSD wires.... they were not cheap:nono:
and like hellslegion said just cap it off at the mani:)
jsnowman76
Oct 17, 2006
289
Elk grove, CA
WOW the previous owner was one messed up dude. I have now idea what he did to this car. I guess that just goes to prove that you should never buy a car from a used lot :nono: this is going to be one "fun" winter project. thanks for the help and the pics guys.
catback
bitterville
NashMan said:
does your coil pac's get wet there
the only time that the coilpac gets wet, is when i wash the car.
when i spray the front fender it sprays in < more my fault than anything:biglaugh:
but out in the rain it doesn't get wet <that i've noticed.
then again, it doesn't see much rain either ;)
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
is it cause your car doesn't run? :icon_razz
:biglaugh:
jsnowman76
Oct 17, 2006
289
Elk grove, CA
anyone have a resevoir tank for sale... mine seems to be missing.
where is this SUPPOSED to go?
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
lol at the loop, there is a metal braket on your afm on a line coming from the charcol canister it goes through that braket on you afm then it goes to the bottom nipple on your loop there, lol, then the top one goes to a line under your 3000 pipe.
