Some Help
suprablitz
9
harrisburg
Fellas
Im having trouble strating my car and when it does turn on I have to hold the idle up so it wont die. I checked all my sensors and codes only code I have is 42 wich is speed sensor. So I check timing and I mark the belt with a marker for the tdc marks pull the cps. I reinstall after checking making sure its lined up with groove mark and the belt. Crank and the same shit. I check the cps again trying to see if I see the cam lobe tip through the oill fill neck. I cant so I check the belt again and the marks for tdc are at the wrong spot like the belt jumped:cry: . So I adjust everything again so I can see the cam lobe and know it just cranks without trying to start. :1zhelp: Could it be wrong belt? I got it from the dealer and it goes on pretty tight like normal.
Thanks for any info guys
Eric 91t
bowsercake
828
Irvine, Ca
42 Vehicle Speed Sensor Signal
Diagnosis
* No "SPD" signal to ECU for 8 seconds when engine speed is between 2,500RPM and 4,500RPM (7M-GE) or 4,000RPM (7M-GTE) and coolant temp is below 80°C(176°F) and neutral start switch is off.
Trouble Area
* Vehicle speed sensor circuit
* ECU
