Some help with the idle
NA86.5
NA-T Complete Yo
Jan 20, 2006
459
Alice Tx
Well my car is idleing at 1100 rpms all the time and i wanted to know how i could fix this, it idles like that all the time even after its warmed up let me know how to fix this guys :1zhelp:
canadianbacon
Extra Crispy
Dec 10, 2005
226
Coquitlam, BC
Try turning your air in.... and then out 5 and one half full turns. The air is located on your throttle body, if you did not know this already. Also check timing it could be too far advanced. I run @ 15 degress +. Be sure to short out your diagnosis box with a wire first before setting your timing. Instuctions to short it out are on the underside of your hood. Look on the right side of your hood there is a sticker indicating the two boxes in your diagnosis box. Good luck.
