Hello all,
I will be making much more power than stock and was planning on replacing my stock 89+ style mounts with solid ones similar to the ones at AAP etc... A friend seems to think that running two solid motormounts on the 7M is a pile of garbage.
According to him the main reason to switch to a solid mount is to stop the engine from torqueing over in the engine bay. This is great, but isn't really necessary since the 7M is a straight 6, a very well balanced engine as opposed to the big v8's. The 7M doesn't torque all that much, again unlike those v8's. His main concern is that it changes the natural harmonics of the engine and therefore could possibly cause premature failure in the bottom end.
His other reason is that it shakes the car like crazy, which I kind of like. This extra vibration rattles parts loose which means more maintenance. Have you found this too be true?
His solution was to run one solid mount, or weld tabs to the stocker, to stop the engine torque and one stock to absorb the vibrations. This seems logical to me and was also seconded by a co-worker who is a big mopar junkie and ex-Dodge mechanic.
Also, is there any difference if the mount is made of steel or aluminum?
