Soarer 1jz injector signal problem.
supbrah86.5
14
Saint Leonard, Maryland
So after a few months of running great, a developed a dead miss while driving home. So far what I've found is a dead miss on cylinder 2 and 6 which share the same signal from the ecu. I've swapped coils and plugs and the number 2 injector, the miss stays on 2 and 6. Additionally I overlaid the signal wires to 2 and 6. Using a power probe I'm getting a pulse on these injectors but not as strong as the working cylinders. I haven't moved the cylinder 6 injector because its a pain in the ass and I wanted to see if anyone has seen this before. Could an internal short in the number six injector cause disruption to cyl 2 as well? Or is it simply a blown ecu.
My other question is if it is the number six injector, can I swap it with just one 2jz injector until I get my tax return or is that dumb?
If using stock injectors you need the 370's.
I would open up the Ecu before doing anything. Likely that a cap has leaked.
Radial
252
Norway
to really test a capacitor, you need a "Oscilloscope". A very expensive tool for electronics.
Better off by just soldering in new caps, thats like...15$ in parts maximum.
Choose caps at the same size (Farad, Micro-farad, piko-farad etc..), but preferably higher voltage and Temperature ratings. Stock caps is usually low temperature rated (maximum 60c or so) and should really rated 80c in very hot climates.
