So my car has a miss...
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
And i can't figure it out for the life of me.
The car went to maft pro recently and the set up is done right... aside from this miss. I do not know if i had it before either, it has been a long time.
So basically my AFR'S are good, it is just when i hold the gas, you can hear it missing, as if it is going to blow up or something lol.
I had oil in my galley, but that was due to the galley bolts being loose and shooting up a bit of oil. None of that anymore. Everything was cleaned up.
I did the spark plug wire trick by unplugging each, because i thought one of my wired would be fucked, but they all just made the car sound like a Subaru.
The car sometimes wants to stall, but never does. And this is all at random.
My Maft pro map reads -7.5 psi at idle, which is like -15 inhg of vacuum, but i do not think i have a leak... Anything anyone can think of that i haven't tried yet?
The car boosts to 7 psi as well, and last night i even beat an Sti from a roll. what do you guys think?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
got a clip of the sound? BTW, vacuum should be more around -20inhg. If it were me, anything lower than 18 at idle i'd expect a leak ;)
also, does it do it on a cold engine vs. hot or both states?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
This just occured to me.
Not long ago...(when i had an engine not covered in melted plastic and charred components :) )...i had a similar issue. It was actually and injector. It actually got unplugged when i went to mess around with the ISC. Same symptoms you are having. Its something to look into
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
CryoSlash;999226 said:
will do tomorrow. Nothing helped today.
My mechanic said that an injector clip being unplugged would fuck it up, same with a clogged inj.
like i said ;)
the car WILL run and drive, just kinda shitty. though For being down an entire cylander, personally my car drove pretty damn well lol
