i think i am finally done with my supra. the passenger side is SMASHED, there is a knock in the engine, it leaks oil form the valve gaskets, and the tps needs to be adjusted.
so.
i found a white n/a 5spd for 1200 bucks about an hour away form where i live. nothing wrong with it besides a very chips in the paint on the passenger side.
i want to put a 2jz engine in it, and get one small turbo for low rpm, and one BIG turbo for high rpm, AFTER i rembuild the engine entirely with solid, dependable parts, and have all the rubber pipping turned to metal ones. with about 15 psi of boost, how much hp do you gusy think i will have, or is this build even worth my time? also, anyone wanna buy my hunk of crap supra?
so.
