so i need some help with ride height settings
rodama5anthony
430
Bay Area, CA
i just install stance coilovers on my 89 super and while examining the car after the first test drive i noticed that the tires had rubbed the top so i need to raise the car a bit. i was wondering if anyone had any recommendations on ride hit cus i read through the stance instructions and it doesnt suggest anything.
This section is "Moderated" so each new thread needs to be approved by a Mod before it can be "seen", posting the same thing again will just result in more work for the staff cleaning up the mess.
rodama5anthony
430
Bay Area, CA
super.secret.supra.club;1639146 said:
why dont you raise it till it stops rubbing?
i can do it but i justed wanted to know if anyone knew exactly how low i can go with out it rubbing cus i want to be as low as possible and if i just aimlessly raise the car i might be as low as i possible can. u get what im trying to say?
No one will be able to answer this as it's dependant on each car and the way it's been setup, ie: Tire size/wheel offset/suspension settings and so on.
May as well ask "How long is a piece of string"
rodama5anthony
430
Bay Area, CA
LOL alright ill settle for that answer thanks guys
rodama5anthony
430
Bay Area, CA
IJ.;1639160 said:
Thought he said it was rubbing the Liners??
ya it is rubbing the liner i wasnt completely sure what he meant by rolling the fender ^^ so ya i dont need to roll my fender but thanks SSSC interesting information
If it's just rubbing at the lumpy bits of the Liner you can heat them up with a heatgun and push them in a bit, I ran 265/35/18's on the front fairly low and did this to good effect.
1,304
San Diego, CA
he said the "rubbing the top". could be the top of the liner or top of the fender. i thought the fender
How long is a piece of string that I found while trying to lower my suspension so that it's as low as possible without going to low so that it rubs my inner liner while going over bumps but not in straight lines?
