so my buddys shop finally got their dyno! they did a dyno day yesterday and i got to see what my car makes. the first pull was on wastegate which is 15psi. the other two were on 18psi with my boost controller. made good numbers on 15psi but on 18psi it was fading boost. ive known it fades boost but didn't think it was that big of a deal but it is!! you can see at 5000rpm it gained about 50whp then just faded to about waste gate power....15psi is what i like to autocross with so thats why i have such a low wastegate pressure. i guess when i dragrace just going to swap springs in the wastegate since it controlls boost so much better than any boost controller ive seen. either way im happy with what it did on 15psi and now i know that boost fade is not something to blow off if going for max power. my boost controller is cool to gain some power on the fly but it just doesn't control boost near as good as the wastegate. i could prolly fiddle with it to get it to work better but i don't think the two can be compared in precise control. can't wait to see how it pull this next weekend at drags. going to drop in springs for 20psi maybe 22psi with some leaded 110. should be interesting cause previously at the drags i ran oxgenated unleaded 104 at 20psi with boost controller but im sure it was fading boost bad. so it should really move compared to before and im thinking the 110 will be safer than the 104. and this is on a dyno dynamics which read lower than a dyno jet. the "corrected" numbers to a dyno jet was just under 400whp :biglaugh:
