Ok Solved all my recent problems due to BLOWN TURBO Gt35 t4 Godspeed turbo. I got a replacement, and used the correct oil feed restriction flange this time.
http://www.youtube.com/watch?v=YGzEWbWvMV8
Now I have an oil leak, but its not coming from the turbo oil seals, not from the feed line, and not the return line. The ground is dripping in oil.
Honestly, I know it sounds crazy, but is it possible for the aftermarket HEADER manifold to fill with oil somehow, and smoke a storm? There is a small cloud of white smoke, NOT COOLANT, OIL! I cannot pinpoint the location, but It is coming from the header! ???
Ugh has this happened to anyone before? I just installed the brand new turbo, no problems, Idles Beautiful, runs Beautiful, I primed the turbo for 30 seconds, then warmed the car for 30 minutes. Now its sitting outside, but I cannot pin-point this oil leak. Again, it is not the oil feed, or return line. Not the valve covers, not the turbo seals, NOTHING IS SMOKING OUT THE EXHAUST either. Maybe the Heat wrap around the headers? IT did get some oil on it, but would it smoke this much? ???
