Was think about tinting or smoking the tailights and i wanted to see if anybody has done this and if they have if they have pics of it.
daledoe said:Here's a like to the some thread: http://www.thesupraforums.com/showthread.php?t=496
xarewhyayen said:gp... look up VHT niteshades. I used it on my last car and got them quite black. Looked good cuz it was a black car. If you use this stuff do like 3 really light coats from about 2 feet away if you want it light...Make sure you clean the surfaces before you paint them really well with alcohol as it leaves no residue and cleans very well.. do it with no wind and make sure you are doing fine coats or you'll see alot of dots. If you do get a dull finish use some polishing compound. should clear it up. Hope this helps.
you use the sand paper after you apply the clear coat to help get rid of orange peel/ripples. Just sand, not too hard..gp-7mgte said:do u use the sandpaper before or after you spray the lights, and how hard do u use the sandpaper?
NDBoost said:you use the sand paper after you apply the clear coat to help get rid of orange peel/ripples. Just sand, not too hard..
supradan22 said:anybody have em on a white car?
