Smoke, smells, suggestions to where to start trouble shooting?
Supra0089
367
New Hampshire
Today, I took the car out for a spin with a friend. Did a couple 50 to 120 pulls. I started so smell something funkie, but all gauges were okay, so I just drove casually back home.
Car sat for about an hour, I got back in it, started it up and backed it up...to my surprise through a cloud of blue/black smoke. Sometimes the car before smelt like fuel in this situation cause it runs a little rich on startup...but this was definitely different. Driving the car around, it performs and seems to run well..a/f looks normal under all conditions.
I fiddled with the car a little bit...and if I give it a quick idle to 3k rev...a puff of the same blackish/gray smoke now comes out of the pipe. On idle, it does not seem to smoke. Coolent level is fine, going to check oil after it sits for a bit.
Here is the background. Car was driven with lex/afm/550/walbro setup on a 50 trim turbo with metal HG for about 2/3 years with never any probs. This year I put in a JT62, slightly used turbo, a safc and vpc, and got the car tuned. It dynoed at 402/408whp at 16/16.5psi and has run strong for about 2 weeks. Car has about 30k miles on a new crate motor.
If anyone needs more info, my build thread link is in the sig.
Any ideas as to where to start troubleshooting would be helpful. I'll probably get a compression/leak down test hopefully next week somewhere.
Any guesses as to what I'm dealing with?
Thanks in advance.
Black means fuel. Gray can be anything from fuel to coolant to oil.
Might have a bad injector.
Supra0089
367
New Hampshire
Update:
Oil level looks fine. Last changed...about 300 miles ago.
Drove it around, seems to drive normal...power feels good...a/f looks fine under all conditions.
I take it the only way to check this is by pulling the injectors?
