Smoke Cloud!!!!!!!!!
mudbutt
The Count of Monte Fisto
Feb 28, 2006
22
Little Rock, Arkansas
I'm trying to diagnose my problem. Oil spitting out the valve towersback), oil hitting fan, oil everywhere. Oil comming out exhaust along with clouds of smoke at idle and when I give it gas. Hesitation when I step on gas. Can anyone help me? Thanks
MKIIINA
Destroyer of Turbos
Plano, TX
mofo.... i jsut typed up a nice intelligent reply and the forums hung.....
recap -> many problems
valve cover gaskets sound like they are leaking
front seal on the turbo could be blow
-check turbo for shaft play
- replace turbo more than likely
-pull plugs for oil being burned...this could explain miss
turbodriz
mk3 onwer
Feb 25, 2006
471
newyork....N.c
-pull plugs for oil being burned...this could explain miss[/QUOTE]
aNY CAN BE ANYTHING THAT WAS JUST LISTED. MY CT26 WENT BUT IT DIDN'T BLOW IN THE INTAKE SYSTEM IT DUMPED IT INTO THE EXHAUST. DO YOU HAVE ALOT OF BLOW BY.
THAT IS ALOT OF OIL TO BE BLOWING, tAKE THE FEED TO THE INTAKE, WITH THAT MUCH OIL BEEING BLOWN YOU SHOULD HAVE PLENTY IN THERE. IF NOT YOU HAVE OTHER PROBLEMS.
