Smoke between shifts
socc924
CT and Philly
oh... well you would most likely only vent to the atmosphere if you had a aftermarket bov. You probably arent. Its hard to tell you what the cause it. If I had to guess I would say valve seals but it can be a number of things. sorry I couldnt help more
87CandyBlueT
553
Kentucky (NKY)
Appears to be grey smoke but the the video is taken from about 15 feet beind me, So it is hard to get a good look at the smoke.
I don't think my BOV is vented to the atmosphere. My BOV is located from the pipe running to the right side of the motor to the turbo elbow from the small pipe running next to the 3000 pipe. Is this correct?
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Does it smoke at any other time?? If it only smokes after you have been on the throttle then your looking at rings and possibly turbo seals.
N
NDBoost
Guest
if your car only smokes in boost its more then likely turbo seals.
Rings would be more of a constant smoking and valve seals would only smoke after sitting for a bit at a red light or on a cold start correct? Someone correct me if im wrong here.. because i have similiar issues, i smoke when i go into boost and when i get out of boost; my turbo has lots of shaft play and i keep finding a few little pools of oil on the compressor inlet lip when taking the accordian hose off as well as a thin layer of oil on the IC pipings
