Ok. I just got done repairing a BHG that took out my rad and heater core.
The heater core was repairable. I took it to a radiator shop and they fixed it. They pressure tested it and re-soldered where necessary.
I installed my new Koyo Rad, the repaired heater core, and an HKS 1.2mm headgasket. I torqued my ARP studs to ARP's specifications and retorqued after 5 heat-ups and cool-downs.
There are no temperature shifts at all. Temp gauge reads normal. Idle is normal with the exception of a miss type of sound. The idle speed doesn't fluctuate at all. A fellow Supra owner said that the slight stumble/miss at idle is inherant to 7M's. Is he accurate...I don't know?
I have no leaks outside the car; but, occasionally I get wiffs of coolant inside the car and I am now starting to hear that ever so sooooooooothing water fall sound. I felt around on the carpet by the floor vents and as far back as I could reach behind the center console; but, found no coolant or wet carpet.
My biggest fear is that this could be related to the head, block, or headgasket. Is it possible for a cracked head, block, or leaky head gasket to cause these symptoms?
I am going to Napa after work tomorrow to pick up a coolant system pressure tester. Would a cylinder leak down test be a good thing to do at this point in addition to the coolant system pressure test?
Thanks for your thoughts!
