Smaller hole than Wastegate Valve? Consequences?
aheroicrevolt
Le Kittens Meow
Sep 30, 2012
100
Grand Rapids MI
Hello everyone,
I have an exhaust manifold that has about ~34mm wastegate hole.
But I just purchased a Tial 44mm wastegate.
What problems can occur if I don't port the manifold hole larger?
Should I port the Manifold to 44mm as well? Orr...what should I port it to? Larger or smaller than the wastegate?
jesse_rc1991
169
austin
Port it. No harm in making the hole bigger, chances are you will boost creep if you dont which is not good. ebay manifolds claim to have a set size hole, but if you measure it with a dial caliper its actually smaller
Sep 19, 2011
510
Des Moines, IA
is the flange for the wastegate made for a 38mm? it may or may not work fine, only way to tell would be to run it and see. if its only a 30 some mm hole, id get rid of the 44mm gate and just get a 38mm gate. no reason to go larger if it cant flow it. Is it a tubular manifold or cast?
