Ok just thought i'd show some pics of my winter project:
I've got 4 runners welded in. I'm using 43mm throttle bodies off of the 4AGE Silvertop. Still far from done just thought i'd share.
Two questions:
1. If I tap a port into 1 cylinder runner is that enough vacuum for the brake booster?
2. Can a 4AGE TPS work with the 7MGE ECU. I plan on using MAFT Pro if that helps answer it.
thanks and hope you like it so far
Two questions:
