Sludgy brown goop around the water pump
BosoMKII
497
NorCal
Today I took the water pump off to have a look. Everything inside was clean and the water was clean ( though I think it is very new ) but the long bolts on the top right where covered with this brown goo. Where do those long bolts go through to? Why would they be all sludgy like that? What little relevant info I could find searching suggests BHG. Any thoughts?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
dude i whould not really worrie about it but i whould pop the cap off the rad and see if the rad core is gumed up and if it is replace it and flush your system out
that bown good is old coolent way past it's time
BosoMKII
497
NorCal
Interesting. Ok. There is also a ton of oil and sludge on that side of the engine, looks like a P.S. leak. Hopefully that is part of it. Thanks for the advice.
Anyone else?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
The lines to your oil cooler are usually weeping through by now if they haven't been replaced, and they are on that side. They only cost a couple dollars - well under $10 - to replace with new oil hose from any auto parts place.
The one end to the oil filter fitting is a PITA to get back on, though.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
use fule line for the oil cooler every one has it in stock
BosoMKII
497
NorCal
Its an N/A, no oil cooler right?
There was an auto tranny oil cooler but its gone, doesn't seem like the lines went by there anyway.
Just looking at most of the stuff I am taking out, doesn't look like I will be keeping much. I will probably re-do every line that stays. Thanks for the advice guys.
