Slave Cylinder dead?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Car's been on jacks without a trans or clutch for about a week, got it put back together yesterday, and last night i went to try the clutch and the pedal just fell to the floor. Ok, i bleed the system from the slave cylinder and it works. About an hour or 2 later i get the car off of the stands and i go push the pedal, does the same thing but now it has alittle tiny bit of clutch feel at the very bottom of the pedal. There is no brake fluid on the ground. Do I just need to bleed it again or is my slave cylinder/master cylinder dead. When I open the bleeder a constant stream of fluid comes out by the way.
pinoydude2003
8
san diego
id take out the slave and inspect the boot. mine just tore and i had the same symptoms. also when you bleed it, r u using a tube to a container of fluid so air doesnt get back in?
