Single turbo guys
Clint
AzSupras
Apr 4, 2005
1,463
7
Mesa, Arizona, United States
Okay Im still putting my car together i have the motor in and getting ready to run vacuum lines and water lines so I have a few questions.
What did you guys do about the ISC where did you run the hose to that goes to the turbo side?
Which vacuum lines did you guys use and did you half to plug most of the vacuum ports on the intake plenum?
Has Anybody ever plugged up the water lines to the ISC and throttle body?
I will be running on stock computer until I can get my hands on a stinger...
OneJoeZee
Retired Post Whore
aboard the Argama
I took that metal U pipe from the ISCV off and left the ISCV open. You could put a breather filter on it. I don't recall capping off any vacuum lines on the intake manifold. I think I used the one that goes around the back of the head to the stock BOV for something else that was already tee'd off on that side. Don't remember. :nono:
Clint
AzSupras
Apr 4, 2005
1,463
7
The car idles with the iscv left open... Makes since I guess lol. Joe I tryed to ninja edit the thread becuse I know your upgraded twin but we dont really have to many people running sweet twin turbo kits :p...
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
I have a 1jz'd 240sx with a twin gt28r.
Clint I am not sure what is the iscv, but I suspect it's the pipe at the back of the turbo-side valve cover. If so put a filter there, that needs to suck in air while idle, otherwise your car will shut off.
OneJoeZee
Retired Post Whore
aboard the Argama
Yes, that one. The valve itself sits on the back of the intake manifold.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
i put a breather filter on my ISC, still have the pipe for the vaccum hardline.
im still using all of my vacuum ports on the intake manifold for one thing or another.
i plugged all of the water lines for the TB and the ISC, iirc you only need them for cold climates
a local guy around here is running a stock ecu w/safc on his T72 1J, and hes not having much problems at all with his car. im running Mine's w/ and AFC and i have no problems whatsoever.
OneJoeZee
Retired Post Whore
aboard the Argama
I looped those two sum' bitches together. They were capped before when I got the car but those caps bust over time. They're kinda tricky to reach at. I'm sure overtime the hose will wear out too but the hose is alot easier to pull on to remove.:naughty:
I hate caps. All 4 of the water caps burst in me within a week of putting my turbo kit on. The ones on the right side(TB ISC) were unrelated to the turbo kit, they just happened to finally give around the same time. The two on the left side(old turbo water line sources) busted each of their caps within a day of installing them. They were cheap 'need them now' autozone types but still.
I looped those two, and the other two on the intake side. Coolant leak and busted cap problem gone!
PS: I said "bust a cap" teehee:momaru:
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
lmao
when i was putting my new HG and Studs on, i took the crossover pipe and had the two coolant line things cut off and tig welded, cuz all the locals guys have had the same problems with bustin caps
Clint
AzSupras
Apr 4, 2005
1,463
7
damn I was thinking about welding my closed but I used caps instead... Uhm well I guess time will tell haha... Maybe If I bought clamps they will hold better???
does anybody know the size of breather to put on the iscv?
OneJoeZee
Retired Post Whore
aboard the Argama
I'm sure if you clamp them good, the caps will stay. I just didn't feel like putting more caps there with all the cap bustin going around. :biglaugh:
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
does this mean that you will be offering twin t25 manifolds and downpipes for the 1j as well :naughty:
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Zerocool said:
Oh man if Dre makes them they will sell like hot cakes for fat children! :naughty:
yep, and if he included oil lines for them, I would buy a set (provided its reasonably priced)
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
i went to the local auto parts store, got one of the little ricer boy breathers (the stainless steel lookin one) and it fits inside the rubber piece that connects the ISC to the pipe on the back
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
I blue printed the manifold & downpipe for the twin gt28. So if someone want a kit I should have one made within a week or so.
Not sure what the price would be but it seem like It should land in the 650-750 range. I want make sure they are cheap enough for ppl to afford with out forsaking quality. We'll see.
