China manifold:
44mm Tial Vband flange standard
Divided T4
Now fits out of the box. Grinding and mods to make it fit are apparent, but it fits none the less. Some can benefit from having the flange faced. Out of 5 of these manifolds, none have exhaust leaks. Comes with a warranty if purchased through 935.
XO2 manifold (knock off of the stryder style):
HKS 50MM flange
Does not fit out of the box. Requires redrilling of a couple of holes. Wastegate flange is too close to the trans, required cutting and rewelding at an angle. Works well once the issues are worked out. No warranty. These are the ones you will find on eBay from Xo2.
Others?
Note: It is best to comment on a manifold that you HAVE or have used. Posting comments such as I heard or my baby momma said that this doesn't fit, doesn't really help anyone.
