I have a Q.
Recently, the supra started showing some very odd cooling characteristics. The outside temperature was around 95 or so, and as I came down from cruising speed to stop and go portland traffic, the temp gauge started fluctuating like it does under boost with a BHG. What is odd, is that when I romped on it, instead of going up, like with a bhg, the temp jumped back down. This seems like a classic hot rod syndrome, with the mechanical fan not moving enough air at idle to cool the system down. The ac was on, and it was hot as hell outside, so I figured I might need to upgrade fans and radiator to keep things in check during the hot summer months.
So after it cooled down for good, I hopped on the dyno, made 4 4th gear pulls, and the temp didn't budge. The huge fans were blowing away, and apparently it kept things in check.
On the way home, things were fine until I hit traffic, and it started fluctuating again. Right when it was almost up to the H, I found a break in trafic and got up to 70, and it cooled right back down. But then it started dancing up and down even at speed. Only when I went through shade would it settle down. Still, boost made things better, rather than worse. When I let off the throttle, it heated up. It ran this way for 50 miles or so, and then was fine for the remaining 10 miles home. Until I got to the driveway, then it heated up. I parked it and let the turbo timer count down, and it stabilized right before the car shut off.
So what's it sound like to you? I pulled the thermostat, and tested it. It is fine. It's a 93 deg unit, so I'm replacing it with an 85 deg unit. The water pump usually weeps before it stops pumping correctly, right? The headgasket is a year old Titan 1.5mm torqued with ARP studs to 90 ft.lbs. The coolant was flushed last summer, and it didn't have any cooling problems all last summer or this winter. Also, turning the heater on full blast had NO effect on temperature. It seems that if the headgasket was to blame, then the temp would have gone up under boost, and been fine when cruising, but this was NOT the case. Do you think I just need more airflow? Or a bigger radiator? Or is there a mechanical problem with the motor? I'm compression testing it this weekend to see if I've lifted the head, but I'm really doubting this is the problem due to the erratic charactaristics of the problem. Any insight would be most appreciated. It semms that plenty of us are having cooling issues this summer.
Thanks in advance!
-Jake and Heidi
Thanks in advance!
-Jake and Heidi
