So I finally wanted to do a build thread to share my project. I wanted to show it at SILV08 but issues with the tow rig and time and a fuct coilpack threw a wrench in my plans. So here it is, I wanted to do a 600-700hp drifter with the ability to drag and road race. My mom bought this car for me when I was 17. It was origionally a maroon 1988 turbo targa with the gray package and bells and whistles. I took H.S. auto shop with it and learned how to wrench on it. I am now 29 and have been through a 1,000 stories and phases with it. Through the last 12+ years I have worked on, broke and modified almost everything 2..... 3..... 4 times. I have done the majority of what you see in the last 3 years I have done most of the work including all the welding and fabracation. There is way too much to explain but I will be happy to share what I've done and how. I have alot of build pics in my photobucket album and I will post some highlights. Right now I am awaiting a new coilpack from Summit so I can start it again. I was having issues with the AEM and the Weldon fuel pump, I think I have to redo the fuel pickup anyway, BIG props to Bigaaron and Driftmotion, Jack from Suprasport, and many others including my very tolerant girlfriend, but here she is, her name is Mary-Jane.
If you want to see my whole album:
http://s90.photobucket.com/albums/k246/simpsons7s/cars/
I have some loose ends and cagework that is coming but here are some clicky pics and a list of mods:
Drivetrain:
Boss Stage 4 Turbo (TO4-E)
Ron R. Front Facing Intake Manifold
90mm Throttle Body
Nitrous Express Direct Port Injection (175 Shot)
Probe Forged Pistons (.040)
Eagle H-Beam Forged Rods
Clevite 77 Engine Bearings
Balanced and Blueprinted Engine Build
HKS Metal Head Gasket 2.0mm Stopper
ARP Hardware (Main,Rod & Head)
5-Way Valve Facing
Port & Polish & flow tested
Manley 1mm Oversized Valves
Brian Crower 272 Camshafts
Titanium Valve Springs and Retainers
AEM Adjustable Cam Gears
Grays Racing Timing Belt
Aeromotive Fuel Pressure Regulator
Semen’s 850cc Injectors
Driftmotion.com -8 SS Fuel Lines
Weldon Racing Fuel Pump (180gph 120psi)
Dual BOV’s (Turbo XS BOV and Tial BOV)
3” Intercooler
2.5” Custom Intercooler Hard Pipes
4” Custom Downpipe with Cutout
3”Custom Exhaust
Apexi N1 Exhaust
Suprasport.com Short Shifter
Driftmotion.com Stage 4 Clutch
Driftmotion.com SS Clutch line
ARP Flywheel Bolts
Koyo Radiator
Custom Wire Harness
Custom PCV Routing
Custom Power Steering Setup
Custom Intercooler Mounts
Engine Management:
AEM EMS Standalone (SEE ATTACHMENT)
Innovative Wideband 02
GReddy Exhaust Temp Unit
GReddy E-01 Boost Controller
HKS Turbo Timer
Suspension:
Tien SS Coilovers
Energy Suspension Strut Bushings
Energy Suspension Front and Rear Bushings
LIPP Torsion Bars
Trust Front Strut Tower Bar
Megan Rear Strut Tower Bar
Suspension Techniques Front & Rear Sway Bar
Custom Rear Reinforced Sub frame & Bracing
BIC Nylon Sub-Frame Mounts
Volk Racing AV3 Front 18x8, Rear 18x9 +35
Axxis Brake Pads
Powerslot Rotors
Upgraded Power Steering Rack
TIP Power Steering Rack Spacers
All new ball joints and tie rods
Exterior:
Shaved and Frenched EVOII Body kit
3 Stage Pearl White
Frenched Antennae
Rear Wiper Shaved
Rear Badges Shaved
Battery Cut-off Switch
Interior:
Corbeau Forza II Racing Seats
Auto Power Rollbar
Corbeau 5pt Racing Harness
MOMO E-Brake Handle
MOMO Steering Wheel
Trunk Mounted Battery
Optima Blue Top Battery
Stainless Battery Hold-down
Suprasport.com Intercooler Block-off Plate
and a few that I left off......:naughty:
Drivetrain:
90mm Throttle Body
5-Way Valve Facing
3” Intercooler
3”Custom Exhaust
Apexi N1 Exhaust
ARP Flywheel Bolts
Koyo Radiator
Custom Wire Harness
Custom PCV Routing
Engine Management:
HKS Turbo Timer
Suspension:
Tien SS Coilovers
LIPP Torsion Bars
Axxis Brake Pads
Powerslot Rotors
Exterior:
3 Stage Pearl White
Frenched Antennae
Rear Wiper Shaved
Rear Badges Shaved
Interior:
Auto Power Rollbar
MOMO E-Brake Handle
MOMO Steering Wheel
