Simple Fuel Pump resistor Q
tougespirit_jzx81
7
Fairfax, VA
okay i know this is a retarded :aigo: question BUT.....just gimme a y or n awnser.
If the fuel pump resistor on a 92 Supra Turbo (7mgte) (little silver box that bolts on to the FPR bracket on the exhaust side fenderwall) wasnt plugged in, the car would, start but wouldnt run for more than a few sec, am i correct?
-Kyle
shaeff
Kurt is FTMFW x2!!!!
10
Around
if the resistor isnt plugged in, i cant see the car starting at all unless you jumper it with a wire. so your answer is probably. :)
-shaeff
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
What shaeff said.
The resistor pack is there to limit the current to the injectors. It's needed because the injector coils are low "impedance" (an incorrect term btw). Without the resistor pack the coils in the injectors would fry in short order.
Since the injectors are supplied with 12 volts through the resistor pack disconnecting it would result in no injector operation. No injectors = no fuel. The car may fire from the cold start injector if the coolant temp is low enough but it wouldn't run. It wouldn't even start if hot.
figgie
Twin Cities, Minnesot-ah
jetjock said:
What shaeff said.
psst
fuel PUMP resistor NOT fuel injector ballast ;)
Two different items :)
IHI-RHC7
"The Boss"
Oregon
Heh. He's got you there Jetty ;)
IMHO just cut the yellow wire and be done with it. Unless you want to perform harness surgery, then by all means, remove the assy properly.
