Sigh car troubles for my bday
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
Turning on an intersection and my car dies, Battery is good (even tried jumping it just incase), plenty of fuel, it tries to start like normal... it just doesnt start =| going to check the codes when i get the car towed here.... anyone have a few tips at what i should look at first =P
also a note is that the injectors are 5,000 miles old
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
alternator finally gave out?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
First off, Happy Birthday..
If the battery is good it can't be that. The TCCS actually compensates for low battery voltage (to a point) so as to keep the engine running well after a charging system failure. It all comes down to spark and fuel. When you get to checking it out a shot of starting fluid will quickly pinpoint which direction you should look in. I'm betting it's electrical in nature though, even it it's a lack of fuel.
tlo86
Jul 24, 2005
3,914
Colorado
hehe thanks jetjock,
where is the Cam position sensor anyhow? that is a big possiblity
, i am thinking it might be the wires since i have broken the thermostat wires plenty of times
going to check spark plugs when i go back to my car in an hour
LexingtonBlue
84
Tacoma
It is at the front left corner of the engine....between the power steering reservoir and front left corner of engine, and behind the thermostat....it is round with a black plastic cover.....there's a green connector above it. That was where I found loose/broken 15+ year old wires.
LexingtonBlue
84
Tacoma
good luck......and don't forget to check other stuff like spark plugs, etc....man, I learned so much by going through what you're going through right now. LOL
cartman
7m powa
Jan 29, 2006
Chilliwack
Do you have a battery hold down in place? If not your battery can slide towards the radiator and the postive terminal will short out on the rad and you car will die. Happened to me.
tlo86
Jul 24, 2005
3,914
Colorado
it was in place originally, now it isnt because i tried two different batteries
once i get my car home i'll try the ohm and volt meter on everything, and yeah lex i would read the TSRM and haynes manual about my suspension and i learned way more when i had to replace everything! hah what a busy month that was
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Yikes, now there's a case where baking soda could be handy in a couple of ways. Batteries must be restrained, not only to prevent electrical hazards but to prevent it from suffering a short service life. Vibration is bad for a flooded cell lead acid battery.
CPS wiring: Yep, check that out. If it doesn't start with fluid it's probably no spark and that'll be the cause. I'm somewhat puzzled by all these CPS connector failures though. I've never had a problem with any connector on the car but it's obviously happening.
boost fiend
852
Rockford, Il
mine did that once apon a time. wiggled the cps wires. nothing. wiggled the wires going to the coil packs and fired right up. 15+ year old wires are a pita. good luck and happy birthday. hope it get's/got better.
tlo86
Jul 24, 2005
3,914
Colorado
have to delay it until tomorrow, tried checking the codes but my car doesnt feel like being touched today guess....
