short vid before standalone
quake
toyota tech
Apr 13, 2005
619
r.i.
so the stinger is tuned pretty well still have a bit to do at the mid range of boost. Running about 16deg of timing up top and this thing just pulls!! The log feature comes in handy if you dont have a crazy friend to ride with you. Mind you the af's are in the low 10's up top. Boost is set to 16.5 psi and i will see about a dyno vid for friday.
For all looking to make power safely go standalone!!! no comparison to the stock ecu and a piggy back, i should have done this long ago. Still need to install my dual pumps and relays also cams as these are stock.
quake
toyota tech
Apr 13, 2005
619
r.i.
Aaron hooked it up with support and putting up with my questions. Big up to him and his shop for his work on this set up for the mkiii supra:icon_bigg
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Good stuff ….. I am running a SAFC II and to me the thing was too easy to tune. I dont see how people charge so much to tune with that thing. How difficult was the stinger to get it up and running? How easy was the initial tuning compared to tuning with the very “user friendly” SAFC considering you can just change the data files and run the stock ecu settings.
I am the kind of guy that does things on his own and I am in the building process right now. I have put together a parts list which most of the parts will be from bigaaron and I am thinking the stinger is the way to go did you get a plug and play harness?
What’s your feedback on the installation and tuning?
quake
toyota tech
Apr 13, 2005
619
r.i.
I picked up a plug and play harness as i drive the car everyday and did not want any down time. This allowed me to tune my standalone and swap back to the stock ecu as needed. One i got the car driveable i left the standalone in. You cant compare a standalone and the afc it's like a t88 vs a stock turbo, all i can say is get one. No more fuel cut unless you want it total timing and fuel control also car pulls to 7k no problem
